zgeezer Posted July 29, 2016 Share Posted July 29, 2016 Ok, I wish to replace the fusible link from the passenger side rail to the starter in an early 240z. I have the harness side intact. I do not have the link. The quick disconnect is a latchable plastic holder with one male blade on the body side and a matching female on the link to the starter. That blade is an unusual size. I believe it is something in the order of 10 or 10.mm. Does anyone know where I might find these connectors and latch "box"? I am not interested in purchasing a complete fusible link: only male/female/and plastic connector. With these connectors, I expect to wire a relay/breaker/fuse box without sacrificing the body loom. g G Quote Link to comment Share on other sites More sharing options...
Miles Posted July 30, 2016 Share Posted July 30, 2016 (edited) First try search I got this: http://forums.hybridz.org/topic/104419-s30-and-s130-wiring-harness-repair-kits-you-need-this-if-you-have-an-l28e-or-l28et/?hl=%2Belectrical+%2Bconnector+%2Bsource Also, search for Dave the headlight harness guy (vendor section). He is the most informed member on Z electrical equipment I am aware of and may have sources for the connectors you seek. Keep searching as I recall threads on sourcing connectors within the last two years e.g., http://forums.hybridz.org/topic/64233-help-finding-electrical-connectors-240z-wiring/?do=findComment&comment=600039 Edited July 30, 2016 by Miles Quote Link to comment Share on other sites More sharing options...
