jersey280 Posted August 1, 2016 Share Posted August 1, 2016 Hey guys, Small issue with my fuel gauge on my 1976 280z L28. Recently had my fuel sending unit rebuilt, which turned out fantastic. While testing the unit I was able to determine that when I move the lever to the "full" position it moves the interior gauge needle well past the full line and when I move the lever to the empty position it rests in the half full position on the gauge. Is there something I can do to adjust the needle on this gauge or is it deeper then that? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
jacky4566 Posted August 2, 2016 Share Posted August 2, 2016 You can adjust the range on the sender itself. Pull it out again and you will notice that the wiper is attached with a small set screw. Undo the screw and tweak the armature on the rod until satisfied. You can see the screw here: http://zparts.com/zp2wp/wp-content/uploads/2016/03/25060-E4100_9202_1ks.jpg Quote Link to comment Share on other sites More sharing options...
