Sign in to follow this
joey.youssef
What gasket to use? Need help
Hello,
I have 1978 280z... The head is cracked so I am replacing it with a P79 head.
I am wondering if someone has experience putting a P79 head on a N42 block.  Does everything line up properly?
I am buying a complete gasket set for my 78' 280z but do I have to buy the head gasket for an 81' 280zx to match the P79 head or would they be the same?
My build is going to consist of the following:
N42 Block rebored
New Flat top pistons
Grind camshaft if needed with new bearings
P79 Head resurfaced (0.010") with complete valve job
Remachined stock cam 245-270 degree with lift .460"
Headers/Exhaust
K&N Cone
Edited by joey.youssef
Share this post
Link to post
No problem putting a P79 on an N42 block, or an E88 on an F54. I believe that the Felpro head gaskets have all of the possible coolant holes, so there shouldn't be an issue with holes getting  blocked off. It is always a good idea to confirm when doing assembly. The Felpro oil pan and cam cover gaskets are the best IMO.
Share this post
Link to post
