Techno Toy Tuning Tie Rod
Hear it is.
I bought longest and was realized too long and bought another set but I am not sure which one. They are sold as individual so you need two.
The reamer is 1-1/2" taper which I found on amazon.com. The cheapest I found was just fine.
Reaming with hand-held drill is not so difficult. It tends to drift (tilt), but can be corrected easily. Just check frequently until the stud seat in the taper. Slow speed, moderate pressure and big drill (800 w) may be the points. Or, just fix the arm on the drill press until you satisfy vertical of the hole and go.
Forgot to mention, taper reaming requires cutting oil.
Edited by KAZU
  • 1 year later...
I'm running the T3 tie rod ends and their NCRAs.  I like the adjustability of the tie rod ends, the improved geometry as grannyknot pointed out, and the increased clearance between the tie rod and wheels (15x9).   Hard to beat the quality and design of T3 stuff.
