Namor Posted October 1, 2016 Share Posted October 1, 2016 I just saw this video and figured someone here might be interested in trying it out. Quote Link to comment Share on other sites More sharing options...
Roberts280Z Posted December 26, 2020 Share Posted December 26, 2020 After having previous poor satisfaction from a dash cap, I decided to try the Polyvance method. I had three crack areas: The middle area went all the way through the foam. I followed the exellent instructions as given in the Polyvance video, and in their step-by-step instruction. I widened all the cracked areas, and in the large middle crack, I used their FiberFlex to weld in a mesh backing plate. This shows one of the smaller cracks after filling with FiberFlex: After sanding the filled areas, I applied their passed dash filler, which is a bondo-like product: I then primered the entire dash, sanded, and applied their Flextex VT texture spray: I also retextured the glovebox door so that it would match. I'll need to do the center console as well. This was all done back in July, but I have not yet reinstalled the dash since I am still painting the interior. Quote Link to comment Share on other sites More sharing options...
socorob Posted May 5, 2024 Share Posted May 5, 2024 I used this stuff on mine about 10 years ago. The areas I patched still look great, only problem is the rest of the foam is 50 years old, so it eventually cracks in new and exciting places. If you're able to, get a dash from Hong Vu or one of the other ones supplying it so you don't have to go through pulling the dash again. Quote Link to comment Share on other sites More sharing options...
