Polyvance dash repair
Namor
  • 4 years later...
After having previous poor satisfaction from a dash cap, I decided to try the Polyvance method.
I had three crack areas:
The middle area went all the way through the foam.
I followed the exellent instructions as given in the Polyvance video, and in their step-by-step instruction.
I widened all the cracked areas, and in the large middle crack, I used their FiberFlex to weld in a mesh backing plate.
This shows one of the smaller cracks after filling with FiberFlex:
After sanding the filled areas, I applied their passed dash filler, which is a bondo-like product:
I then primered the entire dash, sanded, and applied their Flextex VT texture spray:
I also retextured the glovebox door so that it would match.  I'll need to do the center console as well.
This was all done back in July, but I have not yet reinstalled the dash since I am still painting the interior.
  • 3 years later...
I used this stuff on mine about 10 years ago. The areas I patched still look great, only problem is the rest of the foam is 50 years old, so it eventually cracks in new and exciting places. If you're able to, get a dash from Hong Vu or one of the other ones supplying it so you don't have to go through pulling the dash again.
