mforget Posted March 26, 2017 Share Posted March 26, 2017 Hi, i know this subject has been beaten to death but i couldnt find a clear answer. Im currently restoring a '77 280z and plan to refresh the stock suspension components and install some lowering springs. No coilovers for now. We will soon do the body job and put some ZG flares, so i am wondering what offset i should look for with Rota grid 16x8 or 16 x 9 wheels? I would like to have a square tire setup but i dont know if that is possible with those cars using stockish suspensions. Im pretty new to the Datsun world. 245 wide tires all around would be perfect for me but looking on forums it seems that 225F/245R is very popular. Any inputs on this would be really appreciated. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
mforget Posted March 27, 2017 Author Share Posted March 27, 2017 Ok, I may reformulate to make this easier Do 16x9 -15 offset Rota grid wheels would fit on 4 corners on a ZG flared 280Z with stock suspensions? Using 245 tires on 4 corners, or using 225F/245R Thanks! Quote Link to comment Share on other sites More sharing options...
seattlejester Posted March 27, 2017 Share Posted March 27, 2017 (edited) ^There ya go, much more focused and answerable. The preferred setup for standard zg flares is the rota setup at front: 9 inch wide -13 offset and back: 9.5 inch wide -19 The suggested wheel size would be very close in the front to the preferred side, a little closer to the flare. Out back you would be about 16mm sunken in compared to the group buy offset. It will fit both inboard and outboard, you will have a bit of room to play with in the back if you wanted to go a little wider. Tire size is a bit harder to suggest as manufacturers kind of vary and definition of fit is different from person to person. Edited March 27, 2017 by seattlejester Quote Link to comment Share on other sites More sharing options...
mforget Posted March 27, 2017 Author Share Posted March 27, 2017 Hey thanks for those infos! I really appreciate! Quote Link to comment Share on other sites More sharing options...
