MerloZ Posted April 9, 2017 Share Posted April 9, 2017 I got my l28et running. However all the settings confuse me. Yhe car runs but quite bad. I have the afr, VE , and ignition tables copied from one persons file. For spark settings i have it set up according to DIY autotune for the trigger disc setup. And the rest of the file is from another persons similar setup. People say to just copy fuel tables to a new file instead of trying to run someone elses tune. I copied every setting from the simialer tune aside from the tables and the spark settings. Could those be the reason the car seems to constantly run rich. The car is backfireing and crackleing alot. Timing is pretty solid. And plug wires are correct. Also by decreasing the VE table values it seems to almost make no difference in how it runs. I know all this is very vauge but any help is apreciated as always. Thanks Quote Link to comment Share on other sites More sharing options...
Conedodger Posted April 10, 2017 Share Posted April 10, 2017 What version? Quote Link to comment Share on other sites More sharing options...
MerloZ Posted April 10, 2017 Author Share Posted April 10, 2017 What version? Quote Link to comment Share on other sites More sharing options...
MerloZ Posted April 10, 2017 Author Share Posted April 10, 2017 Ms2 extra. 3.4.2 Changing the nbers on the VE table seem to not effect how the car runs Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted April 11, 2017 Share Posted April 11, 2017 Adjust your required fuel to change the fueling overall. What size injectors? Quote Link to comment Share on other sites More sharing options...
MerloZ Posted April 13, 2017 Author Share Posted April 13, 2017 Adjust your required fuel to change the fueling overall. What size injectors? Okay i will try that. Stock injectors 269cc i believe. Quote Link to comment Share on other sites More sharing options...
