turbogrill Posted June 26, 2017 Share Posted June 26, 2017 Hi, Several people in this forum has used 300zx outer valve springs in their L28 engines. It gives you a slightly stiffer spring than stock. I ordered a pair of 300zx (84-89) outer springs but their diameter is much much smaller than the L28 outer springs. I double checked with MSA and they are confident they sent me the correct stuff. What did I do wrong here? Schnieder/JWT recommends the same springs for VG30E as L28 so it should work. Quote Link to comment Share on other sites More sharing options...
Oblithian Posted June 27, 2018 Share Posted June 27, 2018 Did you find an answer for this? I have found a lot of vague rederences to doing it but no complete write up. (As an aside, different manufacturers have different variations in their product specifications). Quote Link to comment Share on other sites More sharing options...
turbogrill Posted June 27, 2018 Author Share Posted June 27, 2018 They sent me the wrong springs, the z31 outer works great. A litttle stiffer then stock so good for high rpm. But they do coil bind if you have a high lift cam. Maybe a little before .480" Quote Link to comment Share on other sites More sharing options...
Oblithian Posted July 9, 2018 Share Posted July 9, 2018 (edited) Thank you! Do you think .460" is ok? Edited July 9, 2018 by Oblithian Quote Link to comment Share on other sites More sharing options...
turbogrill Posted July 10, 2018 Author Share Posted July 10, 2018 5 hours ago, Oblithian said: Thank you! Do you think .460" is ok? Yes, 99% sure Quote Link to comment Share on other sites More sharing options...
Oblithian Posted July 13, 2018 Share Posted July 13, 2018 Perfect 👌 Quote Link to comment Share on other sites More sharing options...
rreford Posted May 18, 2023 Share Posted May 18, 2023 I am about to buy springs for my P90A L28 turbo. When you go with the outer Z31 springs, are you running the stock 280 inner springs? Quote Link to comment Share on other sites More sharing options...
