30 ounce Posted September 24, 2017 Share Posted September 24, 2017 Almost finished with my LS1/T56 swap and have a question about the final wiring hookups. I have a Sikky wiring harness that made it really simple to integrate everything but a I few questions. The harness has a "Charge Cable" that hooks up to the back of the alternator as well as the single "sense" wire that is plugged into the alternator. The Camaro battery cables have an extra wire that looks like it connects to the alternator also. Do I need to have a connection directly from the battery to the alternator like that? Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted September 26, 2017 Share Posted September 26, 2017 Double check with LS1 tech. I used a Camaro alternator and did a resistor across the field wire and ran one wire to the battery. YOU NEED two cable one to the starter and one to the alternator. HTH, Richard. Quote Link to comment Share on other sites More sharing options...
