baby_Carlton Posted December 17, 2017 Share Posted December 17, 2017 (edited) Hi all, I'm wondering if anyone knows how to make KMAC camber plates work with OE struts (non-coilover conversion) for 240z's. I've searched around the forums for a while and tried to find some guides or information that could help me make these plates work with my current setup. I briefly talked to John C. a while ago about making them work as he had previous experience with them on a customer's car but other than that I haven't been able to find much. I had a shoulder bushing made to make the KMAC plates work with my struts but after experimenting with them I found that they raised my Z by about an 1-1/2". I'm curious if anyone has been able to fit them without the major raise in ride height. My current strut setup is Tokico Blue lowering springs, Koni 8610-1437 single adjustable shocks and OEM strut insulators. Any information or help would be greatly appreciated. Thank you Liam Edit: changed topic heading Edited December 17, 2017 by baby_Carlton Quote Link to comment Share on other sites More sharing options...
jhm Posted December 17, 2017 Share Posted December 17, 2017 You do know that you won't be able to get much camber adjustment from the KMACs, right? The OEM spring top hats and insulators are the big LIMFAC for camber adjustment with stock struts. (You should still be able to adjust caster, if that's what you're going for.) Just wanted to make sure you didn't put a lot of effort into a solution that wasn't going to give you the results you desire. Quote Link to comment Share on other sites More sharing options...
baby_Carlton Posted December 24, 2017 Author Share Posted December 24, 2017 On 12/17/2017 at 2:37 PM, jhm said: You do know that you won't be able to get much camber adjustment from the KMACs, right? The OEM spring top hats and insulators are the big LIMFAC for camber adjustment with stock struts. (You should still be able to adjust caster, if that's what you're going for.) Just wanted to make sure you didn't put a lot of effort into a solution that wasn't going to give you the results you desire. Expand Yes I found that I get around a 1/10 of the adjustment out of the camber plates vs adjustable control arms. I think I wait to use the KMAC plates if I ever do a coilover conversion. 1 Quote Link to comment Share on other sites More sharing options...
