L20ET ECU Pin No. to Fuel RElay
I have a 260Z with a L20ET, and the fuel pump is currently running straight from the ignition. I want to fix this and introduce a fuel pump relay, but in order to do this I need to know which pin number from my ECU sounds out the fuel signal. My ECU has a single 35 pin connector, and pin 16 or 20 does not seem to carry the correct signal.
Any info is appreciated.
