walkerbk Posted July 25, 2018 Share Posted July 25, 2018 Amongst all the big project I do on the datsun over the weekends, I like to keep a small project going during the week to keep the progress up. This past week project was the steering wheel clamshell. Mine had long ago bit the dust and i pulled it off and through it in a box and left all the wires and such exposed. About 3 weeks ago as im packing and moving stuff around getting ready for a 3rd cross country move, i came across it. All the mounting points had been broken in one form or fashion but I figured it wouldn't hurt to try and repair it. I didn't take pictures of the progress as I am always forgetting to but I got the steps and the end results which turned out fantastic. Step one, the top. With the top side having all the screw mounting points broken away, I was not sure about exact locations and heights of each but I had the base locations. From that, I cut pieces of 1/2in pvc and formed it to fit on the clamshell. I then sealed it to the shell with play-off (I think clay would have been better as the play-do leaked a little). after that, I filled the pvc with fiberglass epoxy (not poly) and added some chopped fiberglass pushing it in with a tooth pick. This gave me strong "peers" as to attach the bottom side. Once dry, I made three cuts down the sides of the pvc and it popped right off. Step 2, the bottom side. I then filled the screw hole or "tubes" with play-do to keep the epoxy in and wrapped ductape around what was left of the tubes. This formed a mold that I could then pour epoxy into to build the tubes back up. The epoxy I used did not stick at all to the sticky side of the ductape nor did it have any chemical reactions. Step 3, matting the two peices. I thought it would be a little harder than it was but this was the easiest step. I just pushed the two sections together and then used the drimel where needed with a sanding drum. It only took about 15 min and made a nice amount of dust. I then drilled holes and inserted screws. I did drill slightly larger holes than needed just to make sure that it didn't recrack but it worked perfectly. Step 4, paint. I did a light sanding just to scuff the surface with some 220 grit and then hit it with plastic primer. I then used 2 coats of textured rustolium spray paint (each coat was 2 light coats so really 4 in total). Although I liked the look, it was slightly rougher than what i wanted so I took 2000 grit and just lightly did a once over just to knock down the high points. I then applied 2 coats of matte clear uv resistant non yellowing. Alternate step 4. I was going to use the primer, then texture (1 coat), then the hammer (1 coat). I figured this would give it a raised texture then a leather grain look. I didn't do this because I loved the look of the texture. I have tried every bed liner and texture coat and this is one of the best. I am very proud of the results and they speak for them selves. If there are any questions let me know. Quote Link to comment Share on other sites More sharing options...
LLave Posted July 26, 2018 Share Posted July 26, 2018 Great work. Thant looks really good. Bookmarking for future reference. Quote Link to comment Share on other sites More sharing options...
