CableSrv Posted August 7, 2018 Share Posted August 7, 2018 (edited) Location: Fort Worth Texas 1971 240 98 LS1 and T56 (LS1 was cleaned up, oilpan gasket replaced, water pump gasket replaced, headgasket replaced, new head bolts, header studs, new thermostat) 99 ECU Complete new body wiring harness Chevy thunder Engine harness Vintage Air AC Mishimoto Radiator Ebay racing seats R180 STI torsen LSD Drive shaft shop 930CV's with STI to 930CV stub axles Rota RKR 17x9.5 with 275R35x17 tires JTR Headers with 1 3/4 primaries Custom 3in Exhaust with a resonator and straight through muffler + tip ( all connections are v-banded ) Speedhut GPS speedometer Speedhut RPM tachometer Prosport Fuel, Oil pressure, Water temp gauges summit 16g fuel cell walbro 255lph fuel pump with corvette regulator/filter Completely new fuel lines Stainless steel brake lines 1in willwood master cylinder 300zx I think brakebooster flipped (came from another z since I needed a bigger one for the 1in master cylinder.. just can't remember off top of my head which one) LED Headlights with relays MSA front air dam fiberglass fender flares Honda wiper motor rebuilt door hinges replaced door latch rubber so it closes good new carpet for interior removed and installed new floor pans and frame rails from baddog parts. Techno toy tuning front and rear strut tower braces. New tokico struts and vogtland springs I have full set of urathane bushings but have not had time to replace them. My build log for the entire thing is here https://imgur.com/a/R7Cdd as well as you can find my forum post as well on this site. Paint is definitely a work in progress, and driver side door was damage before I got the car and needs to be replaced. Door opens and closes good, but window tract is broken and the inner door to outer door skin looks like it was re-welded poorly so it's tweaked. I've driven 20k miles on the car since the LS1 swap and use the car as a daily driver to and from work 25 miles round trip 5x a week. I just bought a 2012 WRX as I need a more family oriented vehicle so need to sell the Z. I was in the process of turboing the car and have almost all the turbo stuff needed for the car minus dynotune and inter cooling piping. Up to you if you want to buy the turbo stuff as well as the Z or just the Z. Here is a list of all the turbo parts I have and spent on it. Turbo stuff: 3in Vibrant tight radius U bend $52.57 Weld Concentric 4" to 3" Reducer, Stainless Steel 304 $20.29 4in U bend $68.00 2.5in U bend $56.00 8 hi impedance 60lb ev1 fuel injectors $169.99 Rev9 RS-series 50mm wastegate 7-10-12-21-29 psi $98.40 T4 Divided Turbo inlet flange $32.75 2.5in flex pipe $23.99 2x 2.5in vband $45.98 Truck manifolds $69.07 Universal FMIC $105.00 GT45 Turbo $203.76 Currently looking at 10k for the car OBO. Edited August 9, 2018 by CableSrv Quote Link to comment Share on other sites More sharing options...
LLave Posted August 7, 2018 Share Posted August 7, 2018 GLWS. If I wasn't so far along I would buy this... and probably many dollars ahead. Quote Link to comment Share on other sites More sharing options...
CableSrv Posted August 7, 2018 Author Share Posted August 7, 2018 Thanks, I've seen cars like mine run higher, but hoping for a quicker sell. Quote Link to comment Share on other sites More sharing options...
CableSrv Posted August 7, 2018 Author Share Posted August 7, 2018 Updating this with more recent pictures as I've been asked by a few. https://imgur.com/a/Qm87BT6 Quote Link to comment Share on other sites More sharing options...
CableSrv Posted August 7, 2018 Author Share Posted August 7, 2018 Sorry for the blurry video.. my phone started overheating in this 102F temp and seems to make the video stutter and become wave then shut off mid video and had to take a second one. Quote Link to comment Share on other sites More sharing options...
CableSrv Posted August 9, 2018 Author Share Posted August 9, 2018 Pending sale, should be done by tomorrow. Quote Link to comment Share on other sites More sharing options...
stevem17500 Posted August 16, 2018 Share Posted August 16, 2018 On 8/8/2018 at 5:19 PM, CableSrv said: Pending sale, should be done by tomorrow. Did u sell Quote Link to comment Share on other sites More sharing options...
CableSrv Posted August 16, 2018 Author Share Posted August 16, 2018 Yes it sold. Quote Link to comment Share on other sites More sharing options...
