spiff Posted October 22, 2018 Share Posted October 22, 2018 Since there is a crank breather and rocker cover breather do I: A- Buy two catch cans and plumb one into each of them and then to the turbo intake B-Buy one catch can with two inlets and one outlet or C-Buy a regular catch tank and connect it to the crank breather and let the rocker cover breather vent to atm or put a breather filter on it. D-Same as C but "T" the crank and rocker breather together before the catch tank. I feel A and B does the same thing, and cost wise is about the same as well. Astetic reasons would put B over A, less clutter in the engine bay C is definately the cheapest, but the breather filter on the cover isn't legal here and it always leaves a oily film that dust and grime sticks to around the breather in my experience. D; Cheap as C but without the grime and it keeps the emissions bit kind of legal. Only thing I can think of is airflow? Two 5/8 lines combining would need an even bigger line going to the can? Or is this not something to worry about? Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted January 2, 2019 Share Posted January 2, 2019 I ran with option "D" for a long time and just put a filter on the catch can top. Just emptied the catch can once a year or so. Instead of the filter you can run that to the turbo intake if you want. Quote Link to comment Share on other sites More sharing options...
