S15/Q45 question
Z-Dreamer
On 11/29/2018 at 8:01 PM, Z-Dreamer said:
Question, I have a R200V Q45 FY33 – 3.692, will a S15 Silvia SPEC R Helical LSD differential work in the Q45 case and would I be able to use the Q45 gears and 6x1output shafts / stubs?
I've been wondering the same thing about the stubs. If yours are out, take measurements. I've got my S15 helical and stubs on my work bench and can compare.
  • 4 weeks later...
No fail, I've just been gone for the holidays! :mrgreen:
I found out that the S15 Silvia SPEC R Helical LSD differential will indeed fit in the Q45 case.
Unfortunately even though the Q45 stub axles are also 30mm and 30 spline, like the S15, you will have to use S15 stub axle shafts because of the difference in length, or modify the Q45 ones to fit the S15 LSD unit.
Here is a useful site I found.
