wingwalker Posted December 11, 2018 Share Posted December 11, 2018 I have removed the non-working clock mechanism and replaced it with a digital outside air temperature gauge. Looks as if this will work fine, but I need to replace the current lens (which has a hole for the clock adjustment knob) with a blank lens. I assume the lenses on the other two small gauges are the same size and interchangeable. And I also assume they are not glued in and are easily pulled. I case you are wondering if I am abandoning an ability to keep track of time, I won't. As part of this build, I plan to put in a more modern radio, and most come with clocks. Quote Link to comment Share on other sites More sharing options...
theczechone Posted December 11, 2018 Share Posted December 11, 2018 I do think that the they are different between the clock and the other two gauges... Quote Link to comment Share on other sites More sharing options...
wingwalker Posted December 11, 2018 Author Share Posted December 11, 2018 Thanks for the info, Theczechone. So, what are my options? And does it even come out, or is it glued in place? Quote Link to comment Share on other sites More sharing options...
