New SS gas tank straps and insulator set / Other 240Z parts
Nelsonian
I have a new, limited run group buy of stainless steel gas tank straps and insulator set for a 240Z stock gas tank for sale both for = $75 + shipping.*SOLD SOLD SOLD*
Original group buy ad:
I have my battery tray removed, stripped and in epoxy primer and set up for a removable option with rivnuts. I decided to go fuel cell and relocate the battery to the rear so this is for sale = $50.
I have a custom and limited run group buy trim ring to customize a stock S30 gas tank for in tank fuel pump/cell purposes. I bought this awhile ago on here and had it cadmium coated then put into the parts collection, = $45.
I have a single, new Tokiko rear right drum brake = $25.
I have a custom rear bracket set for the Arizona Z Car Wilwood  brakes that will allow Wilwood spot parking brakes (120-2374 & 120-2373) to be used. Only have the brackets and had them anodized red, = $250..
All info for setting these up and buying accompanying parts can be provided.
I have a new, unused gas fill tube for a 240Z from MSA, = $100.
Edited by Nelsonian
On 3/19/2019 at 7:40 PM, Mfast said:
whats left?
I still have all the other random parts from that list.
battery tray removed, blasted, epoxy primer
Custom rear brake bracket that allows for Wilwood parking spot calipers. These were made for the Arizona Z Car Wilwood rear kit allowing a rear parking brake option.
Custom gas tank trim ring which would allow you to cover a cut into the stock tank for fuel cell or pump purposes. = SOLD SOLD SOLD
New, unused upper gas fill tube from MSA= SOLD SOLD SOLD
New rear brake for stock drum style brakes = SOLD SOLD SOLD
Edited by Nelsonian
  • 10 months later...
Just bumping this along with the two remaining, lowered priced items...
Still for sale are :
I have a custom rear bracket set for the Arizona Z Car Wilwood  brakes that will allow Wilwood spot parking brakes (120-2374 & 120-2373) to be used. Only have the brackets and had them anodized red to match the rest of the Arizona Z Car parts. I have all the necessary info for completing this = $200 +.shipping...
I also have my battery tray removed, blasted, and in epoxy primer with riv nut set up for easy install/ removal = $40 + shipping
