Info on 7m-gte
  • 1 month later...
I have the same 7mgte swap into my '85 Supra.
Do you have any pics of that 510? That thing must be a screamer/sleeper.
Guest 240Zduz10s
wade T
i saw a guy in town with that swap it was so mean.. i like it alot .. how hard is the swap?
i know the mounts are the same for the 5m and 7m so it all comes down to wiring..
wanna sell??? ;)
240Zduz10s, It was a conversion kit I bought from Don Cubertson who lives near Seattle. So far there's been about 7 MKII/7mgte conversion done by him and two were out of state folks. There's also some folks on the east coast doing these conversions as well.
I did mine in the summer of 2000 it took a good 4 months of pecking away. Here's what came with his kit.
Good used 7mgte engine with the correct oil pan and pick up tube
Toyota's engine rebuild gasket kit
Oil filter relocation kit
HKS metal head gasket
ARP head studs
Firewall heat sheild
1 tube of toyota's f.i.p.g.
Toyota platnum plugs
Custom brackets for factory intercooler
Factory intercooler
All intercooler plumbing
Heavy duty clutch-good to 300hp (7mge pressure plate with stock disk)
Oil cooler and lines
Replacment charcoal canister and lines
Window washer bag and hardware
Toyota oil filter
Custom sub harness built for your application and connection kit
Custom ac lines. if desired
7mgte alternator
Power steering pump and resivor
New belts
Afm
K&N filter charger
CT-26 turbo
Factory ecu
Installation manual
And here's a run down of what I did.
-Replaced the HG with the HKS metal HG.
-Machined the head.
-Ported and polished the head.
-Used the 5mge oil pump with 5mge pan (came with kit)
-Shaved the motor mounts some so the will fit on the forward location.
-Relocated the dipstick using the forward location.
-Moved the alternator harness in the engine bay (5m and 7m alts are on opposite sides)
-Installed the charcol can in a new location.
-Installed the 90 deg oil relocation kit.
-Use 7mge pressure plate which has more clamping power the the 5m one does. 7mgte pressure plate will not work.
-Installed the MKIII Supra intercooler and custom piping
-Had a 3" mandrel bent exhaust system made
-Installed 1 Tacoma head sheld on fire wall
-Installed a custom wire harness under the dash so that the 7mgte can live in the MKII. I know nothing of the wiring part as the sub harness was premade and installed by Don.
-Installed 7m a/c compressor with custom lines
-And installed some misc stuff and fabricated a few things.
The swap wasn't too bad considering at stock boost it gains about 100hp than stock. The car is quite the insane sleeper at 3000 pounds with 4.30 rear end. I dynoed it last summer where it hit 291rwhp and 332rwtq. Here's a pic of it:
My 7mgte MKII
And last, check out the MKII Supra mailing list if you would like to learn more about these wonderfull cars. smile.gif
http://groups.yahoo.com/group/mk2/
Sorry for such a long post.
-Wade
Originally posted by BLKMGK:
You guys see the 700+ RWHP 7MGTE posted over on SupraForums? Dyno vid and all hail.gif
The video was amazing! Never thought a 7m could sound like that, lol. cheers.gif
Guest 240Zduz10s
wade T
thanks for the info.. how much did just the conversion cost ?
ever since i saw that guy smoke my friends mr2 i wanted more info on this swap.
does reg reimer do a good job..(heard of him) ?
id be very interested in purchasing a completed car if you know anyone who is selling there toy send em my way..
Originally posted by 240Zduz10s:
wade T
The conversion kit costed about $3500 and $4000 by the time I had the exhaust, machine work and other misc stuff bought/done.
Yeah, I've heard of Reg. His artical was my the fuel for doing my swap. Infact, I was going to buy his Harness kit till I found Don's kit here in Seattle.
As for a complete running car, I have heard Don talk about providing this very thing. You might try contacting him @ www.nix99.com or call 800-782-0682 Ask for Don Cubertson.
-w
Guest 240Zduz10s
what does the 6m come out of ?? what kinda power does it make stock?
blkmgk:
that 1jz supra would be cool its just too bad the mk iii are so heavy ... alot more fun in a 240 smile.gif
A 6m is is a stroked 5m using a 6m crank. The 6m crank is the same crank thats in a 7m. This engine was what came with MKII Supra in Japan while the US got the 5m. It makes about 180-190 crank horse power in N/A form. The problem with the 6m is that your limited by it's stock fuel system and ecu. I have yet to hear of a 5m/6mgte running more than 10psi with out a ton of $$$ dumped into it. The 7mgte is built for boost.
blkmgk:
Wade,
Sorry for the delay. You can see a couple of photos at http://www.Fiveoneoh.com in the Shasta 2002 pix link on the bottom row--primer wagon. My car dyno'd at 322 rwhp. Hope to get some more pix and the dyno chart up on a 510 site soon.
--Also a couple of photos at
http://www.sromagazine.com/gallery/index.php
hit Shasta 2002 and go to page 27.
Anthony
Nice work Anothony! :D I have always loved that 510 body and with 7mgte, even more so! Very nice custom intake manifold too. hail.gif
-w
Wade,
Thanks. I fabricated the manifold out of 1/8 inch thick aluminum which doesn't make it very light but did make welding alot easier. I used the stock Toyota flange and about an inch of the runners because of space constraints. I don't think I get as much torque as the stock intake as the runners are so much shorter but the hp is still going up at redline on the dyno graph.
--Some day I hope to get some nice shiny paint like your car but I keep upgrading things mechanically--hopefully coming to the end of that soon.--Looks like your conversion is really clean also.
Anthony
