Guest Anonymous Posted May 15, 2000 Share Posted May 15, 2000 Hello, I have decided to undertake the V8 conversion on a 240Z. Which engine do you guys suggest for fuel injection? I need a good engine that I can get a lot of horsepower out of without supercharging it. I would like to run a 5 speed manual. My intention is for some drag racing(but not hardcore). I want a car that I can take to the track and do very well against everyone but, also have something I can cruise around in. I would like to get around 400HP. Models and years would be appreciated. Thanks a lot! Steve [This message has been edited by swat5444 (edited May 15, 2000).] Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 15, 2000 Share Posted May 15, 2000 Steve, Best bet would be to pul;l the engine, harness and trans out of a Late odel F body or Vette if you want to go Fuel injected. Can't go wrong there, as they come with aluminum accessories, and the fuel injection is proven! Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Owen Posted May 16, 2000 Share Posted May 16, 2000 A more expensive alternative would be to go aftermarket. Several companies sell fully programmable EFI systems. Namely Accel-DFI, Haltech, SDS and Electromotive. Accel has full blown kits right down to the manifold and throttle bodies. I don't know if the L98 TPI manifold will fit though...Or you can just get a stocker motor and swap in the programmable EFI system. I went with a TPIS manifold and the Haltech E6K. Expensive stuff, I wonder if I will ever get it started?? Looks good on paper though. Owen ------------------ http://www.homestead.com/s30z/index.html Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted May 25, 2000 Share Posted May 25, 2000 I installed a Chevy 383 in my 76Z four years ago. I had a mini-grand national turbo set up with an 82 ZX engine, but the low end sucked. I did, however, have that turbo set up with Accel's DFI programmable system-what a difference!! I kept the DFI system for the 383 installation and purchased TPIS's LT-1 mini-ram. The whole engine endeavor was rather expensive: custom built 383-$2400, TPIS with accessories-$2000, Crane HR cam (big dif over a non roller cam)-$900, Edelbrock Perf RPM heads-$1000. The original DFI system cost $1500 plus additional for upgraded fuel pump, 30 lb inj's, and 3/8" fuel line. With my 5 lb Paxton, it runs 450 HP at 5000 ft elev here in Colorado. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 25, 2000 Share Posted May 25, 2000 Check out "Dyno Results" about my little 327 EFI. Quote Link to comment Share on other sites More sharing options...
