Alternative gas tanks
Grandpa 1
Hello,
Looks like you posted to the FAQ section that does not allow replies. Please take a moment to make sure you are posting in the correct area.
Camaro gas tanks fit pretty well. The later model F bodies are plastic and can be bought for pretty cheap. They do have a slightly odd arrangement in the V8 form with a jet pump and a built in FPR.
Hope those help. For me I just swapped to all camaro including the filler neck. You could shrink down the stock filler size to match the camaro tank. It is a 1 inch hose, the datsun one is quite a bit bigger so you would have to use some reducers if you were set on keeping the datsun stuff.
