S30Johnny Posted July 28, 2019 Share Posted July 28, 2019 Hello, I just recently bought a 1976 280z. and the only problem im having is the driver side brake light. all the lights turn on but while pressing on the brake that light is really low and isnt as bright as the other side. how can i make it as bright as the other side? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Twisted46 Posted July 28, 2019 Share Posted July 28, 2019 I would first replace the bulb, cheap and easy. The next plan of action would be to check for voltage drop at both plugs. Quote Link to comment Share on other sites More sharing options...
Miles Posted July 28, 2019 Share Posted July 28, 2019 Most likely a bad ground in the brake light harness at the back of the car. Pull out the rear panel and look for the ground wires and clean up their attachment points. Also could be a dirty lamp socket. Pull the bulb and check the socket. Suggest that you down load a schematic for your car. You are going to need it as a Z owner. Ditto a Factory Service Manual (FSM). Quote Link to comment Share on other sites More sharing options...
S30Johnny Posted July 30, 2019 Author Share Posted July 30, 2019 Thanks for the replies! Its Fixed!!!! I took off the back panel and seen that they had replaced the brake light connector . as you can see the blue and red wires compared to the all green. I replaced the light bulb and it was still dim. so i figured they had the connector in backwards. so i switch the wires around and boom all good! Quote Link to comment Share on other sites More sharing options...
Twisted46 Posted July 31, 2019 Share Posted July 31, 2019 Oh boy, you have to love POs! Quote Link to comment Share on other sites More sharing options...
