Guest GillSS1 Posted December 2, 2002 Share Posted December 2, 2002 Has any one swapped this engine into an early Z car? I have a donor car and a Z that needs a new lease on life. Any thoughts? Thanks, Andy Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted December 2, 2002 Share Posted December 2, 2002 Go to www.shotimes.com Then go to Modifications/using other transmissions. Mark Quote Link to comment Share on other sites More sharing options...
Guest GillSS1 Posted December 2, 2002 Share Posted December 2, 2002 Thanks for the info. I have been there, and it is a good resource. Has anyone put one of these engines in their Z? With a super charger it will put out 350hp at the wheels. That would make for a rather potent Z car... Thanks Andy Quote Link to comment Share on other sites More sharing options...
Guest GillSS1 Posted December 4, 2002 Share Posted December 4, 2002 Thanks for the reply. I still love driving my SHO and it will scream up to about 7500 RPM before the rev limiter cuts in. In my research (see link below)I have found that the entire intake runner system is symetrical. This allows the intake to be rotated 180 degrees. With a little work (either take the timing belt cover off or make some spacers to raise the intake a little)this puts the air box by the radiator. Everywhere I have found a SHO transplant, they have used a bellhousing from an 87 ford Aerostar van with a 3.0L in it. This with an adaptor plate mounts up to a T-5 transmission out of a 94 GT mustang. By the look of things it should be a fairly straight forward swap. I have the entire SHO, so I can get the wiring and computer as well. Thanks for all the advise and comments, keep it coming! Andy Healey SHO swap Quote Link to comment Share on other sites More sharing options...
slownrusty Posted December 4, 2002 Share Posted December 4, 2002 GillSS1 - Cool and interesting swap - good luck and let us know how you do and progress. RacerX - Interesting read, pity you don't have any pics to share with us. But sounds like the SHO motor (especially twin turbo'd) would make a pretty awesome project, and some serious horsepower. I have always had a soft spot for the SHO and of course the Yamaha engine is definately the jewel in the package. Regards - Yasin Quote Link to comment Share on other sites More sharing options...
BQR280Z Posted December 5, 2002 Share Posted December 5, 2002 I have a 94 SHO that took a deer, if someone else wants a donor car for a swap. Bill Quote Link to comment Share on other sites More sharing options...
Guest GillSS1 Posted December 5, 2002 Share Posted December 5, 2002 This link is a great place to find whole SHO's for sale. SHO Club Click on the classifieds and you can find an SHO of what ever year that you want. There are some fairly good priced ones as well. THe 89-early 93 all had 5 speeds in them and after that it was automatic only. Andy Quote Link to comment Share on other sites More sharing options...
Guest eric-z Posted December 9, 2002 Share Posted December 9, 2002 don't the later models have a yamaha 3.4L DOHC V8? that wouldn't be a bad swap either but probably costs quite a bit... Quote Link to comment Share on other sites More sharing options...
Guest GillSS1 Posted December 9, 2002 Share Posted December 9, 2002 The 3.4L had some pretty bad cam problems. The cam timing sprocket would walk and ruin the cams. Fairly easy to prevent but still none too cheap. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted January 2, 2003 Share Posted January 2, 2003 I sm currently doing a SHO to 260z conversion. I right now I am just starting on the wiring harness and there is quite a bit of wiring in the harness. I will be using a T5 trans on this convesion. From what I have learned so far is that the wiring is more intiminating than it really is. Mechanicaly the biggest thing appears is that the cooling comes off of the back of the motor. Quote Link to comment Share on other sites More sharing options...
Guest GillSS1 Posted January 2, 2003 Share Posted January 2, 2003 Thanks for the reply. The SHO is a fun car but I think that a SHO powered Z would be a ball. Please let me know how things are going. I am getting the pieces together to do one of my 240's. Happy new year, Andy Quote Link to comment Share on other sites More sharing options...
