240z 260z 280z Coolant temp sensor thread sizes
tioga
Just in case anyone else is looking and can’t find it like me here is the thread size for water temp sensor ports in a 280z thermostat housing. 240z will have the same gauge temp sensor port size.
Gauge Water temp sensor is m16x1.5
thermo-time is m14x1.5
Fuel injection temp sensor is m12x1.5
themo switch port is 1/4 pipe.
side port on a 280z is 1/4 pipe
Edited by tioga
  • 1 year later...
Brilliant, thanks so much for sharing this. Worth pointing out that the ¼ pipe fitting is ISO7 R1/4 thread which is also known as BSPT (Taper), it's not NPT which is a different pitch. (I had thought that NPT and BSP were interchangeable synonyms, but turns out that BSP(T) is a bit finer thread (19 TPI vs NPT's 18 TPI) and they have slightly different thread forms.
Edited by aitch_de
  • 3 years later...
