pontiac 400
Guest 400 ci 280z
two words: smog emmissions. they really put a choke hold on those motors for a while. you would be amazed at how much they cut into a motor performance. i remeber seeing a certain year mopar 318 rateed at only 108 HP and that was flywheel HP to boot
i have a 78 Trans Am from California and they only came with an Olds 403 185 h.p. smog choked power. But on the other hand it does really well on its own unless newer technology v8 passes me by. But then again i have 200,000 miles on the original engine and its just starting to smoke a little. flamedevil.gif I just hope to restify it one day. coollook.gif
if your willing to spend some money those pontiac 400 and 455 engines can run just as hard as most 396 and 454 big block chevy engines. the pontiac engines cost a little more for parts but in some ways are easier to work on and can be made to scream! 500 hp is easy!
look here,
http://www.pontiacpower.com/
http://www.krepower.com/
but if you got stuck with a 403 olds engine cut your losses, swap too and build a chevy because the olds 403 will require a stud girdle and aftermarket heads to RELIABLY run at 500hp which in parts and machine work alone will soon cost more than a chevy swap.
