cruceno21 Posted January 31, 2021 Share Posted January 31, 2021 (hopefully posting in right spot now). Yes I searched, and most posts are ten plus years old and many products are no longer available. So I have two questions. First quick background - I have a nearly completely stock L28 in my 75. She is a fun summer car, I do autocross her (not worried about being competitive) and like to hit an open track day a few times a year. She is currently on completely stock suspension (minus an MSA front sway bar I put in two years ago). I have owned her for just about ten years and have done no suspension work to her in that time... so she is due. I am looking at the Eibach Progressive Pro Kit spring kit (link: https://www.thezstore.com/page/TZS/PROD/classic20b04/23-4042) and wondering on struts. I only really see two options out there that don't require a ton of fab. The Koni Adjustable from MSA or you can find great deals on the KYB non adjustable shocks (https://www.ebay.com/itm/KYB-4-SHOCKS-fits-NISSAN-DATSUN-260Z-280Z-74-75-76-77-78-361002-361003-280Z/353183501677?epid=1529958043&hash=item523b608d6d:g:LlcAAOSwv8ZfR-a3). Some suggest (include MSA description) is to not do the KYBs on performance springs. But to do the adjustable Konis instead (which are about $600 for the set versus $180 for the KYBs linked above). So not trying to be cheap, but that $400 difference can go toward the urethane kit (looking at this: https://www.thezstore.com/page/TZS/PROD/classic20h01/23-4100AZ) and other little things as part of the install. It already has new sway bar end links from when I did the sway bar. Thoughts? Should I suck it up and do the Konis? IF the KYBs just wear out fast, I can do three sets of those before I spend what I did on the Konis. What else should I do while I have it all apart? Not sure I have the tools needed to attempt the spindle pin replacement but that another area I think I rather spend money than Konis. Thanks for any feedback. Thanks. Over the winter I am finishing my valve seal replacement and adjusted lash, just finished tuning my AFM, and next up is finally removing all the AC parts before I move to suspension next month. So doing my research here before I order parts and get it all apart. Quote Link to comment Share on other sites More sharing options...
madkaw Posted February 1, 2021 Share Posted February 1, 2021 Hey northerner , I went from KYB’s to Koni’s . I went with Koni’s with my ST springs hoping I could soften the ride for around town and be able to adjust up for auto cross . The Koni’s seem to be as stiff as the KYBS - at their lowest setting. Now - that being said - it could be my ST springs . Also, your car is probably heavier and with progressive springs you might be able to have a greater adjustability in ride . Quote Link to comment Share on other sites More sharing options...
cruceno21 Posted February 1, 2021 Author Share Posted February 1, 2021 3 minutes ago, madkaw said: Hey northerner , I went from KYB’s to Koni’s . I went with Koni’s with my ST springs hoping I could soften the ride for around town and be able to adjust up for auto cross . The Koni’s seem to be as stiff as the KYBS - at their lowest setting. Now - that being said - it could be my ST springs . Also, your car is probably heavier and with progressive springs you might be able to have a greater adjustability in ride . Hey man, I am back with my Z finally... got her back out and running for 2020, now trying to have more fun in 2021. Anyhow, can you still get the ST springs? None of the sites I have checked carry them, only non OEM ones I have found are the Eibachs. Not sure I am a lot heavier, plus I am planning to pull all the AC stuff before this summer so hopefully drop a few more pounds. Quote Link to comment Share on other sites More sharing options...
Spdrcr Posted February 3, 2021 Share Posted February 3, 2021 I am so glad you posted this. I have the same question. When I look through threads most of the stuff isn’t available just like you said. I was also looking at the kyb. I am finishing up my ls swap and am looking for some wide tires and better suspension. Sorry I can’t help with the answer but I’ll tag along for some info. Quote Link to comment Share on other sites More sharing options...
Spdrcr Posted February 3, 2021 Share Posted February 3, 2021 have you looked at these? https://zcardepot.com/products/coil-spring-set-stock-and-lowered-240z-260z-280z?variant=21384265269361 Quote Link to comment Share on other sites More sharing options...
cruceno21 Posted February 3, 2021 Author Share Posted February 3, 2021 I had not seen those, I rather have a little stiffer, but lower would work. Anyone have feedback on these? Quote Link to comment Share on other sites More sharing options...
