Help identifying brake system
Hi,
As the title states need some help identifying what was fitted by previous owner as the booster and/or master cylinder are faulty and want to replace both to ensure braking system is up to scratch.
I haven't found any other master cylinder that matches this - is has AB-35 embossed on the side and has horizontal mounting holes (these don't match the booster as you can see below).
Thanks,
Edited by Arcdef
New photo
This is the 280Z with the 3UZ swap?  You should put your car info in a sig or just mention it every time.
Looks like the PO had some skills and made a different master cylinder work.  That stack of washers on the top bolt is a clue.
Try to find out if the booster is correct for the car and look at 280Z master cylinders.
Expand
Yes that's me! Have updated signature.
Yes he sure did have some skills, pretty sure the booster is standard as measures 8inches. The master seems to mount with 3 bolts - 2 on either side and one below. I assume the space is missing as it has a different length push rod.
Thanks
Does it have stock drums in back, and disc up front?  Might be that the PO went with a different MC bore if he did some brake mods.
Since the MC is not what came on the car it might be that it's already "newish".  It looks new.  If things work right, maybe just leave it alone.
