dasboikee Posted April 3, 2021 Share Posted April 3, 2021 I am currently in the very early stages of a ~300hp L28ET build and am just trying to feel out what I want to put behind it. The car is 73 240z and had an L24 with an auto in it and barely ran, so I barely have any seat time in an S30. I know very little about the cars history so I am not sure if it was originally an auto car. When I bought the car it came with, what I have detemined is a 4 speed in the trunk. So far, I havenˋt opened the rear end to figure out what gear ratio that I have. I have been doing the research on the options, but know very liitle about the hp/tq specs of the transmissions that I am thinking of. I want the car to be a daily driver with some spirited driving here and there, maybe the odd track day. Relaibility, Longevity, and drivablility of the drivetrain would be my main concern. Options: Rebuild the old 4 speed. I dont know much about these. Some of the info that I have read seems suggests that these can be crap when trying to put more power through them? 240sx 5 speed swap. Thinking the swap kit from Godzilla Raceworks. Trans good to 400WHP? For each of the two options what would be a good final drive ratio or rear end setup? I know there are alot of options with a varying degree of modifications necessary. Am I more likely to blow out the ring or pinion, or a half shaft on the R180? LSD options? Thanks. Quote Link to comment Share on other sites More sharing options...
260DET Posted April 9, 2021 Share Posted April 9, 2021 Your option 2 would be fine to 300 whp only, drags and drifting excluded, a Z32 box is fine for 400 whp, you will need a R200 diff with suitable CV axles. Plenty of LSD options, my choice would be the most expensive (as usual) a OS.Giken. 400 whp can get quite expensive for it to all hold together and take a bit of abuse. Quote Link to comment Share on other sites More sharing options...
