Hindenzerg1266 Posted April 19, 2021 Share Posted April 19, 2021 Good evening all, In the process of chasing down a high idle problem, and I decided to check everything was correct at TDC while I waited on some gaskets to come in. I have the car at TDC, on the compression stroke, both the valves in cylinder 1 are closed (I have the valve cover off to check them), my screwdriver is about halfway through the "lull" to tell me the #1 piston is at it's highest point, and the timing arrow is pointing to the 0 degree mark. HOWEVER, the keyed shaft (forgive me, I believe it's from the oil pump) from the oil pump to the distributor looks like it's off ~11-13 degrees. There are 32 teeth on the oil pump shaft right? So 1 tooth off would be ~11.25 degrees? Going to take a look at it this week, but just wanted to show some pictures and see what you all thought. I took the picture, threw it into OnShape, and then threw in the 5 degree line that the FSM calls out as what we're looking for. Thanks! Quote Link to comment Share on other sites More sharing options...
jonbill Posted April 19, 2021 Share Posted April 19, 2021 I'd say you're right. Quote Link to comment Share on other sites More sharing options...
