Jaconense777 Posted August 28, 2021 Share Posted August 28, 2021 Hello guys, what happened is that I put a new set of felpro performance head gaskets on my s c 350 and I found some antifreeze in the oil again. I removed the left side and it was very tight, however the right side came off very easy, they both were tightened to 70lbs. As the block is a good wrench and the heads are the edelbrock 6073 aluminum . This time I would like to replace the pistons rings, the pistons have marked 0.030 on them, are the rings the same size 0.030? Now if i tighten the heads studs on a cold engine and then repeat it on a warm engine could this prevent the heads from getting loose? I have arp studs and I don’t really know which ones I have. As they just have the arp letters Imprinted on the head. Should I replace them? Your help is appreciated. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 28, 2021 Share Posted August 28, 2021 14 hours ago, Jaconense777 said: I have arp studs and I don’t really know which ones I have. I'd read the ARP instructions to start. They have specific instructions for using their products. Find the product that would be spec'ed for your application. https://arp-bolts.com/p/instructions.php https://arp-bolts.com/p/technical.php https://arp-bolts.com/kits/make.php?_Make=300&_EngModelID=* Quote Link to comment Share on other sites More sharing options...
Jaconense777 Posted September 2, 2021 Author Share Posted September 2, 2021 On 8/28/2021 at 10:48 AM, NewZed said: I'd read the ARP instructions to start. They have specific instructions for using their products. Find the product that would be spec'ed for your application. https://arp-bolts.com/p/instructions.php https://arp-bolts.com/p/technical.php https://arp-bolts.com/kits/make.php?_Make=300&_EngModelID=* Thanks I’ll be contacting arp tomorrow. do you have any idea about the rings? If the pistons have 0.030 marked on them could that means that the rings are the same size 0.030? Quote Link to comment Share on other sites More sharing options...
Jaconense777 Posted September 17, 2021 Author Share Posted September 17, 2021 Thanks for the support. I already figured it out 👍🏼 Quote Link to comment Share on other sites More sharing options...
