1972 240Z door latch removal - tips requested.
In a day or two I will tackle fixing the driver's side door on my 1972 240Z. The latch needs to be replaced, as the spring is broken and hence the door won't close. From what I have gathered there are 3 rods attached to it. Can any of you give me any tips on geting it out?
I recommend to all Z car owners to buy this book available at Amazon:
How to Restore Your Datsun Z Car            by Wick Humble
It details how to disassemble, restore and re-assemble 240z cars. It contains step by step instructions. It has saved me hours and hours of research.
Remove the black door lock plunger knob
Remove the arm rest, door handle chrome cover under door handle and then the door panel.
Remove three bolts holding the door mechanism to the door
Remove the activating rod pivot screw
Remove two bolts holding the door release handle and unhook the activating rod from the door handle
