adsdsasdasdasda Posted July 20, 2022 Share Posted July 20, 2022 I got my car one year ago and it's a 1981 280ZX 2 plus 2 non-turbo Edition. The car went and rode very well for the first year with only 46 original thousand miles on it. Since then I've made some modifications to it and made it a little my own and added about 10-15k MI to it. The car has worked really well over the last year however in recent times there have been some issues where it isn't so reliable all of a sudden. I worked on some dash upgrades a few days ago and got new speakers. It sounded very well and was very pleasant but 5 days later problems started to rise like no other. I drove to a place about 20 minutes away from my house where I volunteer and I noticed that my car wouldn't turn on / engage like it usually would. So I turned the key a few times and was lucky enough to get it working and went to the next location which was 5 minutes away. At this point in time, my car once again wouldn't turn on after it was shut off and my battery didn't have a good level maybe 9 to 10 volts when I tried to start it up again (multimeter). For the next 20-30 mins I tried again and again, out of nowhere got it to start up, and went home. I gave the car a two-hour or so rest and then went to AutoZone, it started up perfectly fine and didn't really have any issues which was interesting. I got my battery tested they said it was essentially shot and I needed a new one in which case I got a new one. I bought the best one, a duralast Gold, and I went home and everything seemed fine. However, I was curious to try it out (starting my car again) and see if my car would start up again after I turned it off it didn't. At this point, I knew there was a large or underlying problem that I couldn't pinpoint so I started to chip at it. Parasitic draw/Battery theory My initial thought was the initial battery was drained due to parasitic draw. I tested it by taking out all of the fuses of the connections wires (chrisfix's video), yet I didn't see any change/ Outrageous DC amperage (stayed at 0). Then throughout the entire night, I tested my battery level and notice it was at a steady 12.8 V at 1-hour intervals for 5-6 hours. At which point I realized it's probably not a battery issue. Alternator theory Now you might ask well maybe it's an issue with an alternator however I did get the car to start every once in a while out of pure luck at which point I would test out the and it would read anywhere from 13.6V to 14.2V constantly never going below that. And I could drive around as soon as I could get the car and it would not turn off no matter what (as far as I suspect I've driven anywhere between 15 to 20 minutes every time) Starter theory This leaves us with the starter being the possible culprit for this entire issue however I doubt that's the issue. Every time I turn the key the starter would crank and you would hear the noise of a car starting up or trying to. Now one important/interesting thing to point out was when I did get my battery checked the following day after all of these issues the auto port did say that there was not enough cranking RPM. However, I've gotten my car to start up many times since then. Other theory (distributor) At this point, I was really confused and I had no idea what could be going wrong as the problem persisted 50%-75% of the time. I then contacted my mechanic and he said it could be a possible issue with the distributor where things could have weird issues but I'm not too sure. When I do have the car running, I drive it like normal and I drive fast and rev high at some points of my drive. This caused no issues so I'm doubting that this is a spark plug issue. I'm not too sure if it's a distributor issue however I'm doubting spark plugs to some extent and thus I'm also the distributor. Other interesting facts/things that I noticed Something that I thought about when diagnosing this problem was an engine needs fuel, air, and ignition to start up. I was able to hear my fuel pump so I'm pretty sure my fuel was there however not too sure about ignition as I'm going to take a closer look at that tomorrow (sparkplugs). The only thing is I haven't gotten a new air filter and my car needs a new one because it's a little dirty, I wouldn't say horrid but dirty. It seems like my car goes back to regular/driveable mode after I give it some time to cool down and essentially relax, but that has to be after every time I drive, even if I drive for 5 minutes around the block (no speeding, etc). Also at one point the car would crank and engage and then die soon after (like 1 sec after) I did have my multimeter hooked on the terminals but I don't know if that would cause that issue. I have a video that I can post of that happening and the car not starting. Video of the car starting up with a little issue Video of the car staring and dying soon after (with multimeters touching terminals) Any other ideas on what could be causing this issue? What do you suggest I try next? Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 20, 2022 Share Posted July 20, 2022 (edited) In your videos the starter and battery sound fine. If you watch the tachometer needle it gives a pretty good clue that you're either losing power to the coil and distributor or the ignition module is going bad. The needle does not budge when the engine is not starting, it should be showing the engine's RPM while trying to start. You can test the first possibility, loss of power to the ignition system, by watching a meter attached to the positive lead of the coil with the key on and when you try to start. Voltage should be maintained above about 10 volts. If you don't have power there then focus on that. It would be worthwhile to clean the connections to the coil and ignition module and see if things improve. The old E12-80 and E12-92 modules are known to go bad eventually though. Wouldn't be a surprise if that was the problem, although they usually fail when they get hot. p.s. the magnet under the stator ring is known to break on those distributors also. That might cause a low trigger pulse to the module at starting RPM. That kind of fits your symptoms. It's not obvious, you have to remove the breaker plate and lift the stator ring to see it. Also, one reason the magnet breaks is because the shaft bushings on those distributors wear out allowing the 6 pointed reluctor wheel to contact the stator ring. Here is a good resource showing some of those things. The result of a worn out bushing is shown way down at the bottom. http://www.atlanticz.ca/zclub/techtips/distributorrebuild/index.html Edited July 20, 2022 by NewZed 1 Quote Link to comment Share on other sites More sharing options...
adsdsasdasdasda Posted July 21, 2022 Author Share Posted July 21, 2022 So I do have power so dont think its that, stay around 10. I think its the distributor, other have said the ignition module on the distributor. When my car wasnt turning on, as I described above, I noticed that that component seemed to be quite hot (like a sufficated laptop). And that there would be not spark/signal to the ignition wire(s). when the car was able to start at some cooler temps then spark/signal was sent to the wires. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 21, 2022 Share Posted July 21, 2022 I described all of that in my post. Good stuff in the link also. Common problem. Good luck. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 23, 2022 Share Posted July 23, 2022 If a diode is bad in your alternator, it will show good voltage but won't have enough amperage to charge properly - ask me how I know... Quote Link to comment Share on other sites More sharing options...
adsdsasdasdasda Posted July 23, 2022 Author Share Posted July 23, 2022 no it charges it it, stable voltage when off, turning on, and when on. 12.8v , 9-10v , 13.6-14.2v respectfully. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 23, 2022 Share Posted July 23, 2022 It will show stable voltage, but not have enough amps to keep charged... Starts fine but later on restarts more and more difficult... Quote Link to comment Share on other sites More sharing options...
adsdsasdasdasda Posted July 23, 2022 Author Share Posted July 23, 2022 well when its cool seems like it has little to no issues. Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 23, 2022 Share Posted July 23, 2022 (edited) On 7/21/2022 at 7:25 AM, adsdsasdasdasda said: I think its the distributor, other have said the ignition module on the distributor Break the ignition system down in to it individual parts and you might get better ideas. The "distributor" is more than just a device to move spark around to the plug wires. It creates a signal to trigger the ignition module. See "variable reluctor" That's what the magnet is for. If there's no signal, there will be no spark. If the ignition module gets the signal but does not make and break the coil circuit then there will be no spark. If the coil circuit is made and broken correctly by the ignition module and trigger system but there's a problem with the coil there will be no spark. As far as the alternator goes it doesn't really come in to play until the engine has started. If the engine cranks normally, at good speed, like it does in your videos, then the battery must have a good charge. The non-moving tach needle is a very important clue. You just have to use it. The tach needle moves when the coil discharges. If it doesn't move it's either broken or the coil is not discharging. In other words the tach needle is moved when spark happens. No needle movement means no spark. Just watch your videos and ask yourself what's going on. Edited July 23, 2022 by NewZed Quote Link to comment Share on other sites More sharing options...
