OEM Brake hose to Wilwood Caliper
Hello,
Does anyone know the OEM brake hose fitting dimensions?
I'm trying to add a Wilwood 120-6816 Calipers and having trouble finding the right brake hose/fitting to work with the stock brake lines.
Any suggestions?
Best,
Nik
If I understand your question correctly, the stock brake line fittings are 10mm x 1.0.  When I mated Wilwood Calipers to my system, I used a brass adapter fitting to mate the OEM fittings/lines to the Wilwood brake line inlet.  All the necessary specs on your Wilwood calipers can be found here:  https://www.wilwood.com/Calipers/CaliperProd?itemno=120-6816
Looks like you'll need an adapter with male 1/8-27 NPT - female 10mm x 1.0.
Hope this helps.
Brakequip BQ187 is the line adapter you're looking for. If you end up using a wilwood master cylinder, BQ50 is the brake line adapter for those 3/8-24 inverted flare male to M10x1 IF female.
~$5/ea direct, I was able to find some locally at MFCP which is a west coast Parker affiliated chain. Midwest/East coasters likely have a similar chain.
https://brakequipproducts.com/product-category/thread-changers/?filter_thread-type=standard-and-metric
