warrenp Posted December 22, 2001 Share Posted December 22, 2001 ok here i am reading the new issue of Chevy High Proformance mag. and on page #62 the ratty looking Nova he's running 14.5:1 compression. on pump gas!!! becasue of his cams 283 degrees duration at 0.050. if he can do that, can i run flat top pistons, with my 6-71 blower and a similer cam. and still run pump gas? any guesses how high my compression would be? oh this is either going on a 350 or 400 sb. i havn't decied yet. Quote Link to comment Share on other sites More sharing options...
pparaska Posted December 23, 2001 Share Posted December 23, 2001 Warren, I think that there's a limit to how well this works. At low speed, yes, the dynamic compression can be low enough for a high static compression engine if the cam overlap is large. But then the dynamic compression goes up at higher rpm, and you might get high rpm detonation. Well, this is the way I understand it anyway. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted December 23, 2001 Share Posted December 23, 2001 I posted this info before but read it ,it will help! -------------------------------------------------------------------------------- DOING RESEARCH I FOUND THIS! INTERESTING? http://victorylibrary.com/mopar/cam-tech-c.htm http://victorylibrary.com/mopar/rod-tech-c.htm -------------------------------------------------------------------------------- heres some more articals you might find of interest http://www.aros.net/~rbuck/rick/rodstudy.htm http://www.stahlheaders.com/Lit_Rod%20Length.htm http://madlab.me.utexas.edu/~yspae/thesis/thesis/node46.html http://www.bergen.org/ETTC/Development/TechPrep/Theory.html http://www.turbofast.com.au/TFcompB.html http://www.smokemup.com/utilities/calc/compression_ratio.cfm http://www.engr.colostate.edu/~allan/thermo/page1/page1f.html http://home.att.net/~jroal/perftheory.htm#Compression AND http://www.motortecmag.com/archives/2001/jun/JUN01-01/JUN010101.html Quote Link to comment Share on other sites More sharing options...
Guest gbvol54 Posted December 24, 2001 Share Posted December 24, 2001 Grumpy, you are indeed da MAN! Now all I need to do is find the time to soak up the info contained in these sites. Lets see, work on Z (greasy hands, busted knuckles) or read tech info with a cold brew..... Damn, the Z took a back seat again! Quote Link to comment Share on other sites More sharing options...
