Ont240 Posted April 8, 2024 Share Posted April 8, 2024 I have a Crane XR3000 ignition box but no optic trigger pieces (3 wire) that would normally go in the distributor. Will a 2 wire magnetic reluctor that a 280Z uses, function as the trigger and what would the wiring be? Crane box has a gray, white, and black wire that would normally go to the optic. What is the function of each wire ? Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 8, 2024 Share Posted April 8, 2024 Probably in the manual. It's both 700 and 3000. Good luck. https://static.summitracing.com/global/images/instructions/xr700 instructions.pdf Quote Link to comment Share on other sites More sharing options...
