Konnor27 Posted 18 hours ago Share Posted 18 hours ago I have an 80’ 280zx with a 82 turbo engine in it, I installed Godzillaraceworks prebuilt single coil megasquirt system. So far it’s given me a lot of issues. I finally managed to get it started but it runs rough at low RPMs (below 2500) and doesn’t idle. My AFR guage reads that it is running super lean, like 18+ I manually lowered the afr table but still nothing Also when I turn the key to off position it doesn’t turn off the car, nothing changes when I switch between off and run on the ignition switch, but as soon as I disconnect the ECU ignition wire from the cars ignition wire everything works normally. also the temp gauge isn’t working on the dash anymore if anyone can help with my issues I would greatly appreciate it Quote Link to comment Share on other sites More sharing options...
madkaw Posted 16 hours ago Share Posted 16 hours ago What do you mean everything works normal when you disconnect the ecu ignition wire . You are probably going to have to provide more info for help . Richard Boyk does remote tuning . Not sure how much he’s on this site anymore - but he is on FB on the Church of L page 1 Quote Link to comment Share on other sites More sharing options...
