awd92gsx Posted May 12, 2002 Share Posted May 12, 2002 Check out some posts by Turbo260 on Zdriver.com. He dropped a turbo engine in his 260 using a 77 ECU and Harness, did a few AFM mods, and runs 11's. Quote Link to comment Share on other sites More sharing options...
Guest 280Tom'z Posted May 13, 2002 Share Posted May 13, 2002 i have a very strong L28 N/A i want to put a turbo on it and i need to know what type of intake sensors i need i do not want to change engines that is not an option and if i used a turbo mainfold for an N42 head what turbos could i use? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 13, 2002 Share Posted May 13, 2002 What's your compression ratio? If you are over 9 or 9.5 to 1, turbocharging is going to be very difficult. Do you have a high overlap cam? Turbos hate overlap. You will definitely need a good intercooler and an aftermarket (read tuneable) EFI system and a very efficient turbo like a T3/TO4E at the very least. High performance N/A engines and forced induction do not mix well. Quote Link to comment Share on other sites More sharing options...
