Flak280z Posted October 10, 2024 Share Posted October 10, 2024 Hey guys, my turbo conversion is running well, no reliability issues. Still running 8psi of boost. My spool is at around 3500rpm with max boost at 4500. A little laggy, but I think that's because of my ebay turbo along with my turbo being mounted on the passenger side. Would someone mind looking at my tune, and making sure everything looks ok. I don't hear any pinging on 91 gas, but just want to make sure. My timing is a little aggressive. Stock l28e engine, n42 block and head, 8psi boost, 370cc injectors. 10_10_24 Tune.msqFetching info... Quote Link to comment Share on other sites More sharing options...
madkaw Posted October 17, 2024 Share Posted October 17, 2024 (edited) If I haven’t mentioned yet - build yourself some detonation headsets and listen for knock . It’s surprisingly easy to hear and cheap to build . Still need a knock sensor mounted someway on the block . It’s easier than trying to wire in a module on the MS . We can look at your tune but would be guessing whether it’s too aggressive . Search on you tube . Besides the knock sensor I have 40$ in the set up . I was detonating on a NA motor but wasn’t hearing it and it was destroying #6 piston . I ended up pulling quite a bit of timing around 4kish . Edited October 17, 2024 by madkaw Quote Link to comment Share on other sites More sharing options...
