Flak280z Posted February 22, 2025 Share Posted February 22, 2025 Have an n42 block without a crankcase fitting on it. What are the options to replace this besides dropping $100 on one on ebay? Using search, I can only find one picture where someone on here replaced it with an AN fitting, but no sizing. Is it hard to remove one from an old block? Quote Link to comment Share on other sites More sharing options...
A to Z Posted February 23, 2025 Share Posted February 23, 2025 I removed the pipe from a block with a pipe wrench. Put the wrench on close to the block so as to not crimp the tubing, Strike the handle of the pipe wrench with a hammer, then push and use a pulling motion as you push it around, it will eventually come out. When re-installing put a piece of wood over the front of the pipe and use a hammer. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted February 23, 2025 Share Posted February 23, 2025 once I got it out, it had some deep teeth marks, I had to take a file and smooth it back up. Painted it and then installed as I mentioned. It had been in there for 50 years, it was "permanently seated" basically. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 3, 2025 Share Posted March 3, 2025 Its just some steel tubing/piping. if your needing to replace one. measure the whole and add a few thousandths and find a pipe the right size to shove it in there. A metal lathe would help to get a perfect size but you can do sufficient job with a flat file. 1 Quote Link to comment Share on other sites More sharing options...
