AC Pulley After MilkFab CF Install
Weber
L6 3.0 Rebello build with MilkFab Crankfire on the required 280ZX front pulley. The ZX pulley has a "B" size (5/8"width) for the AC and the normal "A" (1/2") width for the alternator and water pump. The car is street only and in Houston, TX. I have the complete AC system that I have used for close to 30 yrs and all I really want is a Sanden clutch for my compressor. I will spring for a compressor if it has the right width belt and can fab my own brackets if needed. Sanden won't answer e-mails and most of the parts sellers don't have the answers. Looking for anyone that has solved this issue.
  • 2 months later...
I just put a Sanden 508 on my 1976 280z. I ended up using a slightly thinner Belt that fits the AC Compressor pulley properly. This thinner belt sits deeper in the Crank AC pulley, but doesn't bottom out.  I used the Z Car Depot bracket.
 I'll see if I can find the Belt Part Number. I had to go down a little in size as well. Think I ended up with a 4L-340mm Belt
