ZXT swap
280z-racer
ok got the 81 parts car and took out the ECU and AFM. then i pulled the harness out of fire wall and then romeved from all plugs on motor. is there any other piece of wiring that i need?? like the fusible links or relays or anything else like that?? i really need to know before i junk this car next week.
Guest De Schmaydee
..i'd grab all the relays and fuseable links too.....i'm not sure what car youre putting it in....but if its a zx i'd get the room timer,(and i think there's another box up there around where it is),and all the boxes under both seats.......s
I'm working on pulling all the important parts of the harness out of my car too, I understand that 81's are different but you may need to make sure you get the ignition harness too. Mine seems to have a sub-harness that is taped into the main one...I haven't checked to see if they all go to the ECU or not but I'd check yours to see where the wires go.
