Guest joeyhammer Posted February 13, 2003 Share Posted February 13, 2003 im doing a turbo swap and im going to junk my old vw gti (86) and get a pathfinder and im gonna use my vws pump for the turbo swap.. its supposed to flow 100psi or more.. anyone using one of these or a porsche pump? any advice.. seems pretty easy but with my luck theyll e some odd modification.. thnaks for reading Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted February 13, 2003 Share Posted February 13, 2003 How does a pump flow 100psi? Quote Link to comment Share on other sites More sharing options...
Guest joeyhammer Posted February 13, 2003 Share Posted February 13, 2003 eh whatever you know what i mean Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 13, 2003 Share Posted February 13, 2003 Actually, what you are asking is not clear. You need to find out how much fuel the pump will flow at your static injector pressure added to your boost pressure. For example, a stock Z runs 37psi static pressure. For 15 psi boost, you will need a pump that flows enough fuel for (guessing) 300hp at 37 + 15 = 52 psi. You are probably looking at something like 200 liters/hour at 50 psi to be on the safe side. Quote Link to comment Share on other sites More sharing options...
