Fuel delivery problem....aaaauuugggghhhh
Hello All,
Got a question, My Z car runs on 3 cylindars,Sounds strong but only 3 cylindars Why the vehicle idles, I disconnect the rear fuel injector plug #6 the vehicle idles the same why disconnecting the rear connectors. Until i hit the front ones then the car bogs down again so basically the rear section is dead thought it was the wire. i reversed the wiring and it worked fine in the front. Tommorow i will pull injectors out of intake to check for fuel delivery. Any suggestions.......
Thanks
Ron
