280zx replacement radiatior?
Guest Anonymous
Guest 240hybrid
Like drax said you might wanna try a 280zx turbo radiator, if not MSA has Four row radiators which I believe will cool much better than a stork rad. I think they run about $245.00 new which isnt too bad for a four row rad thats new.
If you want a bigger radiator, then just take your stock one to a local radiator shop and have them recore it with a 2 or 3 row core. Will cool fine for a nissan 6 and most V8's. if not then you probably have something else wrong.
The only problem with the stock radiator is weight. A Griffen aluminum works great at a fraction of the weight. Summit has them at reasonale prices.
