fl327 Posted December 23, 2002 Share Posted December 23, 2002 i guess this is related to charging problems, but it has more to do with an alternator swap. i run the 83 turbo alt in my 75, which had a mechanical regulator i think. well anyways here the weird part, my charging system is good, its just that it reads 15.1 volts when i hit excite rpm when i checked today with multimeter. i do know the alt i have is internal, the wiring plugged right up from part of 75 harness, i am charging, but it is a little high. here are some more symptoms. my charge rpm is kinda high, like 3k or so. it will stay charged even at idel then but it reads kinda high, im scared im gonna blow this alternator or mess up my charging system, any ideas guys?? thanx Quote Link to comment Share on other sites More sharing options...
johnc Posted December 26, 2002 Share Posted December 26, 2002 Alternators will normally show up to 16 volts when charging. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted December 26, 2002 Share Posted December 26, 2002 Yup, like John said, that's normal. A good alternator should put out at least 14 to 14.5 vdc. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 26, 2002 Author Share Posted December 26, 2002 thanx, had a feeling it was ok, but im troubleshooting my whole electrical system planning to up the hp, and want to make sure everything from the alt to the resistors is in top conditon, thanx again. Quote Link to comment Share on other sites More sharing options...
