Surging thur 1-3 gears
Guest Badzx
Guest Badzx
:x My 83 ZXT has started surging reel hard 1st thur 3rd gear, real hard when excellerating in 2nd gear! Just changed oil pump and Re-adjusted the timing. Could the air flow meter be going bad?or Fuel pump? It has no power!
Thanks
if you messed with timing too much it would shut you out when it comes time for boost, like you were hitting some kind of special rev limiter. unless you are running aftermarket efi, then ??? do you mean surging as it will rev up in those gears but go nowhere-check your piping, fuel pump would stutter more than surge, an air leak sounds like whats going on- i think..
Guest Badzx
Thanks For Input, will recheck timing, air leaks, and tps!!
Something I noticed is the exhaust note has Changed???
Instead of sounding like a miss or stumble every several rotation
now it sounds like every other at Idle?
Again Thanks for Input.
