Guest Venture-Z Posted March 5, 2003 Share Posted March 5, 2003 I'm buying an 81zx non-turbo motor to put in my 78Z. The motor is from an automatic and my car is a 5 speed. Can I use the distributor, or do I need to get one from a manual car? Also, will the zx radiator fit in my Z? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2003 Share Posted May 18, 2003 As far as I ever heard, a manual distributor has a manual cable control running to it from the inside of the car and is manually operated from there. But to me, this is old hot rod stuff. How did you get off on this? Quote Link to comment Share on other sites More sharing options...
Guest Venture-Z Posted May 19, 2003 Share Posted May 19, 2003 I ment the tranny type of the car it came out of. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 19, 2003 Share Posted May 19, 2003 Help! I done been exposed! Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 19, 2003 Share Posted May 19, 2003 I think you have to use your '78 dizzy, as they are different not because of the tranny, but because of the ignition differences between '78 and '81. The ZX radiator will fit, but you will have to drill new holes in the support for it. Quote Link to comment Share on other sites More sharing options...
Mudge Posted May 22, 2003 Share Posted May 22, 2003 On the turbo cars, they have a different rev limit (ECU) and the advance is less (according to my Clymer), I dont know about NA though maybe it says in there. If I find it I will post. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 22, 2003 Share Posted May 22, 2003 Mudge said: On the turbo cars, they have a different rev limit (ECU) and the advance is less (according to my Clymer), I dont know about NA though maybe it says in there. If I find it I will post. The turbo cars have advance programmed by the ECU - there is zero advance in the distributor, and the splines are different so they cannot be swapped (unless you change the drive gear as well). Turbo dizzys must go with turbo ECUs or standalone ignition computers. Quote Link to comment Share on other sites More sharing options...
