Granatelli cobra maf for the jwt ecu upgrade
Guest De Schmaydee
Guest De Schmaydee
....i just ordered the jwt ecu upgrade for my 82zxt.....it uses the 420cc inj and a cobra maf.....i've heard its the maf from a 93......(oem p/n F1SZ-12B597A).......i've heard that the Granatelli line of ford parts are much better than stock and i can get one of them for $259 as opposed to $300 for a (probably) stock one from JWT....does anyone have any insights on this?....or a part number off the maf in the JWT kit?
thanks,
......s
The aftermarket units play with "calibration" and I dont generally like them, nor do they generally perform. If the ends of the MAF are larger then maybe thats an excuse to get it, otherwise I prefer to do my tuning elsewhere.
Many people in fact lose performance from the aftermarket MAF. Genral tips, if your MAF comes with a plenum, leave it, if it comes with a screen, leave it. I worked mine over and made tuning a bit of a hell for me, its an example of "free mods" gone too far.
So if you can find a good junkyard unit and the MAF ends aren't too different in size I wouldn't sweat it, stock MAFs on the Fbody that people think sometimes as "small" have gone into the 9s, bone stock, screen and all. I dont know the Stang MAF end size, but people sometimes believe there is a restriction where there isn't one.
If all you can find is brand new, and the Granatelli is cheaper, then I guess I'd go that route, begrudgingly. I'd rather hit a yard or eBay though.
Good luck :)
Guest De Schmaydee
the stock ones are a lot cheaper.....they seem to be 70mm-90mm.....the ones they show in the picts look like they just have 2 little wires running down the middle of 'em ........s
If the throat is bigger, and I believe it is, this could be a good way to run large injectors with a factory Z31 computer. You can tune it with fuel pressure. A more elegant solution than what I'm doing, which is hacking up a perfectly good Z31 MAF, and installing it in a big intake pipe (3-1/2").
Those "wires" are about paperclip thickness, strong paperclip that is. From there crossing each of them, there are the real "sensors." A MAF is just a heater circuit, and once heated it takes a certain amount of air to cool it a certain amount, and that is how they do thier calculations to estimate airflow, instead of speed density where MAP and I think TPS were used together, or maybe it was MAP and intake air temp (IAT).
The issue with running a MAF on a blown/turbo car, is a MAF can only read so much airflow. With a 2-3 bar MAP you are just about limitless. There are tricks to work around this, but tricks can be risky instead of having an actual reading to go with.
