Metric to SAE brake adapters
Guest Mr. Big Business
Owen, are these the adapters that let you use a wilwood prop valves (which wants 1/8 SAE) with 10mm brake fittings?
Henry
I don't know about the prop valve. I coulda sworn my Wilwood accepted the 3/8? SAEs no problem. Tim240Z used some kinda adapter on his prop valve.
I used the adapters for the SAE lines to the metric brake lines on the front Toyota calipers.
Owen
i was wondering this too.... ross would i be able to buy the adapters and hardware for the toyota 4x4 vented swap from you ?
Sure, a few clicks and you're done :wink: Here's my package, even a few spacers anodized depending on which type you require.
http://www.modern-motorsports.com/catalog/product_info.php?products_id=48
  • 6 months later...
"I used the adapters for the SAE lines to the metric brake lines on the front Toyota calipers.
Owen"
?? The calipers are metric as are the brake lines........where did you require metric to imperial adaptors Owen?
Well, this reply is hella old and I only saw it cuz I was looking for the PNs I posted...but, yes the caliper is metric, but my brake lines aren't. I ripped them all out and re-bent re-routed them using the stuff I bought from PepBoys. My old metric fittings were all crapped out from someone using a vicegrip on them too.
Owen
