Guest Lee Smith Posted March 8, 2002 Share Posted March 8, 2002 I have a 69 350 4bl Chilton says 10-1 CR 295 hp. with a 4bl. It needs a valve job. I have later heads that the valves good in. No idea what yr. Will I lose the 10-1 CR? The later 350s have 8.5-1. I like the thought of 295 hp. stock, low $$. I am doing a 77 V8 swap. Lee PS I have 3 finished cars, stock. Pics on ZDriver Rides 78-82-83 Lee Smith If interasted. Quote Link to comment Share on other sites More sharing options...
Mike C Posted March 8, 2002 Share Posted March 8, 2002 You will lose the compression to some degree. The later heads will probably give about 9:1 with the early pistons. I would rebuild the heads on the '69 with new valves, exhaust seats, and guides. David Vizard, "How to build and modify small block chevy cylinder heads" Says the closed chamber heads are worth 20 more hp than the open chamber heads, all else being equal. Or just by a set of aftermarket heads with the 64cc chambers as they have learned a lot about combustion chambers in the last 30 years. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 10, 2002 Share Posted March 10, 2002 There's a good compression ratio calculator at http://www.gafba.com if you want to figure out exactly what the CR would be. Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 10, 2002 Share Posted March 10, 2002 That's the most thorough CR calculator I've seen. With all the data they are asking for, they appeart to be calculating the volume around the piston top above the top ring and using it in the analysis. Very correct, very nice. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted March 10, 2002 Share Posted March 10, 2002 that is a nice cr calculator. it says i can get 9.3 cr with out having to mill my heads on my pont. Quote Link to comment Share on other sites More sharing options...
